1998 Land Rover Defender Charging
1998 LAND ROVER DEFENDER
GRUB72
Electrical problem
1998 Land Rover Defender 4 cyl Four Wheel Drive
Hi I was wondering if I could keep a charger in my vehicle to recharge my second battery at the end of the day. it ill be isolated from the car and other battery durng charge. The cherger will be isolated during normal operation it will be fixed in place in vehichle
Jan 7, 2009 at 11:03 PM
  • 31,937 POSTS
HI there,
You don't need a second charger, you can set the second battery up to charge off the alternator and have an isolator switch fitted so it wont discharge through the first battery, your mechanic or auto electrician can set this up for you.
Mark (mhpautos)
Jan 8, 2009 at 12:05 AM
GRUB72
yeh thanks i all ready have duel system fitted but as i only travel 10 minutes a day to and from work it does not run long enough to top it up so this is how I intend to top it up at night thanks for your advice [quote:f55c08a7c1="mhpautos"]HI there,
Mark (mhpautos)[/quote:f55c08a7c1]
Jan 8, 2009 at 1:45 AM
  • 31,937 POSTS
Hi there,
You can get a solar trickle charger as as well, this will keep it topped up all the time, your spar parts shop should be able to get one for you.
mark (mhpautos)
Jan 8, 2009 at 3:01 AM
