4LO, engine check and anti-slip warning light are all on and flashing
180,000 MILES • 4 CYL • TURBO • 4WD • AUTOMATIC
SIDAMAR
I have the vehicle listed above kdj 150 model. for some time I have the following problem:Three lights on the dashboard: 4LO, engine check and anti-slip warning light.Sometimes the cruise control is deactivated and the number of revolutions increases.Can anyone give me an idea of what the problem is?Cordially
May 23, 2021 at 10:14 PM
  • 55,709 POSTS
Yes, this usually happens when a wheel speed sensor goes out. To be sure lets do a CAN scan which is the future of automotive repair, you can get a CAN scanner from Amazon for about $50.00. here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
You can use an ABS code scanner as well this video will show you how:
https://youtu.be/rTtAnsOlZU4
May 25, 2021 at 3:20 AM
SIDAMAR
May 25, 2021 at 5:05 AM
  • 55,709 POSTS
May 26, 2021 at 3:42 AM
