Lack of power,backfires when accelerating
120,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
SETNSTONE
Car loses power, backfires, bogs down when accelerating from a stop. Have changed; plugs,wires,all coils, MAF sensor. replaced throttle body, new air filter. problem getting worse with time.
Jun 28, 2019 at 1:26 PM
  • 110,248 POSTS
Welcome to 2CarPros.
Have you scanned the computer for codes? I would do that first if the check engine light stays on while the engine is running. First, here is a link that explains about backfiring.
https://www.2carpros.com/articles/engine-backfires-while-running
Now, since there is a power loss, my first suspect is low fuel pressure. Here is a link that explains how to test pressure:
Here are the manufacturer's specs for pressure:
Fuel Pressure No Vacuum 38 to 44 psi
Now, if that checks good, next I would check for a plugged catalytic converter. Here are a few links that explain symptoms, how to check one, and in general how they are replaced:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
https://www.2carpros.com/articles/catalytic-converter-replacement
Let me know if this helps and the results. If you have other questions, let me know.
Jun 28, 2019 at 2:23 PM
