Lack of power on acceleration
205,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
ZIPS
Every now and then the vehicle will lack power on acceleration. it seems that when the outside temperature is between sixty five and seventy five degrees Fahrenheit the car runs well (or I should say I have noticed it does not seem to occur ), anything above seventy five and less than sixty five degrees outside it seems more noticeable. I am wondering if I have an issue with my MAF sensor. I have tried the propane gas around all of my vacuum hoses and the intake manifold, and the throttle body, no vacuum leaks detected. The car idles fine, and other than this issue runs with out problems.
Jan 5, 2018 at 5:06 PM
Good morning.
If you had an issue with the MAF sensor, it would code for irregular readings.
I would check fuel pressure to start to be sure the pump is supplying proper pressure.
I would also look at the timing system. A loose or worn timing belt could also cause this issue.
Jan 5, 2018 at 8:05 PM
ZIPS
I had thought about the fuel pump, and also the fuel pressure regulator, the problem for me is the apparent difference in performance based on the ambient temperature and the fact that it is intermittent. sometimes fine and other times noticeable. I will follow your advice and check the pressures on this vehicle. I need to install a fuel access point to check fuel pressures.
I should add this, it happens when I really want to scoot so if I step on the pedal expecting to just go anywhere between 1800 rpm's and 3500 rpm's this happens. I do not notice it if I just press the accelerator and want to go faster, only during a load situation, uphill or get out in traffic and go.
Jan 6, 2018 at 2:28 AM
You may have to T into the fuel filter to check the pressure.
Jan 6, 2018 at 2:30 AM
ZIPS
I edited my previous post. as this does occur under load conditions, hard acceleration and uphill acceleration. 1800 and 3500 rpm's. is the normal range where it lacks the oomph?
Jan 6, 2018 at 4:08 AM
It sounds like you may have a clogged catalytic converter. you need to have the back pressure tested to verify. you can also drop the head pipe from the exhaust manifold and drive it to see if it is any better.
Jan 6, 2018 at 4:17 AM
ZIPS
1: If the catalytic converter is clogged would I not notice the lack of acceleration at all times and not intermittently?
2: Is there a tool to check for exhaust back pressure?
3: I am thinking if I disconnect the exhaust at manifold - the A/F sensors might behave differently for example make the mixture more rich seeing too much O2 and I really would not know for sure?
Jan 6, 2018 at 5:29 PM
Yes, there is a tool. it is a back pressure tester. you remove the O2 sensor and insert it and run the engine and it measures the back pressure. you would do it on both sides.
If you do not have the tool, dropping the head pipe will let the engine breathe and you can see if the issue stops. yes, it will set codes for the O2 sensors but you just need to clear them when you have it back together.
Jan 6, 2018 at 6:47 PM
