Lack of power
80,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
JUSTIN LEE KELLY
Runs good in idle but when start to move the engine diesels and spits and sputters and can't get it to move faster than 10 miles an hour.
Jun 19, 2021 at 1:47 AM
  • 55,691 POSTS
It sounds like you have a weak fuel pump, clogged catalytic converter or a bad MAF or MAP sensor. to be sure we should run the codes by checking out this guide:
We should also go over this guide as well:
https://www.2carpros.com/articles/engine-has-low-power-output
Jun 20, 2021 at 6:09 AM
