Put gas in car and would not start. Finally started but immediately died. After several times finally started but CEL came on . drive to destination (O'Reily's) code reader. Gave code for EGR valve and crankshaft sensor. I cleaned EGR Valve and drive good for a day. Then next thirty miles stalled six times. Next day thirty miles no problem? A week later drive three miles car had no power on acceleration, stalled ten times hard to start every time and barley made it back home. Changed CSS which fixed stalling and hard to start, but still lack of power. Drove twenty mikes to O'Reily's finally got there, turned car off and over heated! Smoking and leaked coolant from crack in too/upper side of radiator shroud. Code reader gave code for multiple misfires. Changed spark plugs. Previous spark plugs had normal wear and correct gap. checked coil packs, fuel injectors, cleaned EGR valve, fixed radiator and flushed system. Still major lack of power, CEL comes on, white smoke coming out of tailpipe and heavy exhaust smell.
Feb 8, 2017 at 8:40 AM
