Sits and idle all day even when pushing gas pedal to the floor?
164,000 MILES
PERRY101
The car starts with a low idle. Give it acceleration with no change. sits and idle all day even when pushing gas pedal to the floor.. Doesn't shut off.
Oct 26, 2022 at 9:52 PM
  • 55,649 POSTS
It sounds like the car is in limp mode, we should run the codes to see what comes up, also please check the throttle cable to make sure it is connected to the throttle body.
This guide may help as well:
https://www.2carpros.com/articles/reduced-power-limp-mode
If everything checks out the fuel pressure needs to be checked.
You can rent a gauge form the auto parts store for cheap.
Item .................... Specifications
Key on, engine off .................... 448 kPa (65 psi)
Engine running .................... 448 kPa (65 psi)
Oct 27, 2022 at 2:56 AM
PERRY101
No codes showing. Started this morning and ran well until I shut it off then wouldn't start an hour later ran battery down so now have battery on charge. Will check fuel pressure next. Thanks
Oct 27, 2022 at 4:25 AM
  • 55,649 POSTS
Oct 29, 2022 at 7:17 AM
PERRY101
Checked everything and decided to sell it to the junkyard. Thanks, fuel pressure at specs.
Oct 29, 2022 at 7:21 AM
