Lack of acceleration
135,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
X3XXX1991
  • 11 POSTS
Car does not accelerate how it should. You step on the gas and it will not take off. Check engine light comes on every now and then. Because the check engine light comes on i think it probably could use a good tune up:
Fuel pump and fuel filter
Spark plug and wires
Injectors
Or do you think it could be the transmission slipping?
Feb 18, 2019 at 5:46 AM
SCGRANTURISMO
  • 4,897 POSTS
Can you get me the code from the Malfunction Indicator Lamp (MIL)/Check Engine light? I have included instructions on how to retrieve them in the diagrams down below. Please get back to us with what you find out.
Thanks,
Alex
2CarPros
Feb 18, 2019 at 4:19 PM
X3XXX1991
  • 11 POSTS
If you basically just cruise the car it shifts okay. But once you step on it has poor acceleration. The rpm's do not go up and it hesitates to shift into gear.
I bought an obd1 code reader and i got codes:
632
536
213
Help please!
Mar 12, 2019 at 5:06 AM (Merged)
  • 55,748 POSTS
This sounds like you have a clogged catalytic converter. but to be sure lets run down this guide:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
X3XXX1991
  • 11 POSTS
I was wondering if the lack of having a spout connector if it would cause the car to have poor acceleration as well as poor shifting?
When you basically cruise the car (stepping on the gas pedal half way or less) i believe it drive okay. Obviously it accelerates slow because i don't have the gas pedal pushed all the way, but the car shifts well, good how it should. But as soon as i press on the gas (more then half way or all the way down) the rpm's go up but my speed not so much. Like stated has poor acceleration.
Because i don't have a spout connector can this affect it?
Any other ideas? I still need to check to see if my catalytic converters are bad or not as mentioned by another mechanic here.
HARRY P
  • 2,292 POSTS
Personally, I would suspect 1 of 3 possibilities. (1) A clogged catalytic converter. This would not allow the engine to breathe out, causing too much back pressure on the engine, and seriously restricting it. (2) A lack of air flow. Less likely, but if the air filter is unbelievably dirty, the engine won't be able to get enough air in to create the power that you're looking for. (3) A lack of fuel pressure. A clogged fuel filter, or a failing fuel pump, could cause this. Much like the issue with the air filter, the engine wouldn't get enough fuel to do what you're asking it to do, resulting in performance issues.
All that said, is the service/check engine light on? If so, let's get it scanned. Even though this is a 1995, it does have OBD2 (required as of model year 1996). Take it to the parts shop and if they ask what year it is, tell them it's a 1996. Otherwise they may try to cop out of checking it. Report back here with the code numbers (not just their translations, but the actual numbers). We can use that to point us in the right direction.
If you can shoot and upload a decent video of it happening, that might be helpful as well.
If the light is not on, then I'd start with checking catalytic converter performance. The simplest way to do that is to remove the oxygen sensors that are on the exhaust pipe, between the engine and the catalytic converter. This allows the engine to breathe some because the back pressure won't build. But, it'll be loud. Like really loud. Like "wake the neighbors" loud, so do it when no one around would be asleep. I'm attaching images to aid you in pulling the sensors. If memory serves, you'll need a size 7/8 inch wrench to get them off.
The other possibility that I haven't mentioned above is potential serious transmission issues. Hopefully that's not it.
X3XXX1991
  • 11 POSTS
My mechanic supposedly check out my fuel pump, supposedly that is working fine. He checked the catalytic converters, those are fine. he could not find anything wrong. Car still has lack of acceleration. Anything else i should look into?
Mar 24, 2019 at 4:36 AM
SCGRANTURISMO
  • 4,897 POSTS
I would check the throttle body, paying close attention to the throttle bore where the Throttle Position Sensor (TPS) is and clean it real good. When the throttle bore and throttle get to much black "sludge" on them they will contaminate the signal from the TPS to the Power-train Control Module (PCM) and cause this problem. I have included a link for you to go to down below.
Please go through this guide and get back to us with what you find out.
Thanks,
Alex
2CarPros
Mar 25, 2019 at 10:08 AM
X3XXX1991
  • 11 POSTS
My mechanic inspected the Mustang. He changed the spark plugs, removed the throttle body to clean it as well as to install a throttle body spacer. It seems like the throttle response is better off the line. But it still has a lag when you floor it while you are cruising. I am guessing the auto transmission is slipping. What do you think?
Mar 31, 2019 at 2:17 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Is the transmission not kicking down when you go to Wide Open Throttle (WOT)?
Thanks,
Alex
2CarPros
Mar 31, 2019 at 2:56 AM
X3XXX1991
  • 11 POSTS
While cruising if you floor it, it does shift down rpm's shoot up but it has a huge lag. Doesn't seem like it really grabs the gear. just now i drove the car to work. A good twelve miles from my house to work. Drive it going no more then 50%-60% throttle and it drove pretty good. The problem only happens when you floor it (WOT).
Mar 31, 2019 at 3:13 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Well at highway speeds it should have a little get up and go when you drop a gear, but I have a supercharged 1997 Mustang GT with a built 4.6L that is putting out around 375 - 400 horses and that won't pin you back in your seat at freeway speeds. Well maybe a little when drop a gear, but it takes a lot of ponies to pin you back in your seat at freeway speeds.
Thanks,
Alex
2CarPros
Mar 31, 2019 at 9:42 AM
X3XXX1991
  • 11 POSTS
Maybe it is just me because i have not had a v8 before, and this is the oldest car i have had. Especially since all my other cars were manual transmission. only auto car i have or had that i can compare it to is my 2016 Accord. Maybe nothing is wrong, or like i said maybe the auto transmission is at its last leg and going out.
Mar 31, 2019 at 9:55 AM
X3XXX1991
  • 11 POSTS
Also, as i drive i do not switch off the overdrive, but the last time i drove the car i did turn off the over drive and it did accelerate a little better.
Mar 31, 2019 at 1:36 PM
X3XXX1991
  • 11 POSTS
As i cruise the Mustang to work every now and then the check engine light comes on. Sometimes it is on for a few seconds, other times it stays on for a few minutes. Any ideas?
Apr 25, 2019 at 7:06 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Do you have any Direct Trouble Codes(DTC)(s) set?
Thanks,
Alex
2CarPros
Apr 25, 2019 at 7:47 AM
X3XXX1991
  • 11 POSTS
I have an obd 1 reader. i got the following three codes:
1. 213
2. 536
3. 632
Apr 25, 2019 at 8:32 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
I have included the information for your vehicle's three DTC's in the diagrams down below. Please go through the guides and get back to us with what you are able to find out, please.
Thanks,
Alex
2CarPros
Apr 25, 2019 at 1:42 PM
