Labor hours for removing and installing transmission
200,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
MIKEMAIN650
  • 8 POSTS
How many hours does it normally to remove and replace the transmission?
Apr 24, 2020 at 7:53 AM
  • 110,248 POSTS
I attached a picture of labor below. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Let me know if that helps.
Apr 24, 2020 at 10:45 AM
MIKEMAIN650
  • 8 POSTS
I am trying to figure out the labor hours to move and replace transmission in this truck. It is an extended cab 3 door truck as well.
Jan 4, 2022 at 7:22 AM (Merged)
Here is a guide that will help with replacing this unit:
https://www.2carpros.com/articles/how-to-remove-an-automatic-transmission-rwd
I am also attaching all the info needed on part numbers of the units and the labor times. Lastly, I included the process on how to replace the unit. Please run through this material and let us know if you have other questions.
Thanks
