Left tail light, left blinker and brake light not working
11,000 MILES
GERARDO PARRA
I have a motorhome 2018 Coachmen Freelander 22qb. I was trying to hook up my towable car and I must have put the cable the wrong way. I had the RV running at the time. I probably burnt something. So I checked that fuses on both the engine block and under the seat and the fuses are okay. Ever since then, my left tail light is not working. The only thing that works on the left light is the reverse light when put in reverse. So my brake light and my left turn signal and also when turning the lights on do not turn the tail light on at all.
Jun 15, 2021 at 11:22 AM
  • 110,251 POSTS
If all fuses are good, I need you to check for power at the light socket. If there is none, we need to work backwards to see where power lost.
Also, let me know if the vehicle is on a GM chassis. For example, is the RV built on a GM express van chassis.
Take care and let me know.
Jun 16, 2021 at 3:21 PM
