Knocking/tapping noise in the engine bay
127,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
DESTROYER_3600
I was driving home, and it just happened. I would like to know the cause and how to fix it. Rod knock, lifter tap, spun bearing, etc.? What is it? It is supercharged, sub model g60.
Nov 9, 2021 at 2:44 AM
  • 110,246 POSTS
The noise and condition will require different repairs. A lifter tap can be as simple as an adjustment issue. However, a rod or main bearing would likely lead to an engine overhaul.
First, if it is possible, record the sound and upload it for me to hear. Hopefully, I will be able to identify it.
Also, here is a link you may find helpful. Read through it and let me know your thoughts.
https://www.2carpros.com/articles/engine-noises
Also, please understand this vehicle isn't offered in the US, so I have very limited technical information. However, I'll do my best to help.
Nov 9, 2021 at 11:46 AM
DESTROYER_3600
I’m not sure why it didn’t upload the first time but here you go:
Nov 9, 2021 at 2:26 PM
DESTROYER_3600
I had just installed coil overs literally two days beforehand and then this happens after I bought a new exhaust and wide body kit. Like bro if only it had happened sooner so I could have just blown my money on forged internals and a lysholm supercharger. (The supercharger on the car was rebuilt about 10,000 miles ago)
Nov 9, 2021 at 2:32 PM
DESTROYER_3600
Never mind guys I found the problem. Rod Knock. Time for a rebuild and forged internals.
Nov 10, 2021 at 8:47 AM
  • 110,246 POSTS
That isn't good news. Also, I was wrong. The vehicle is offered in the US. If you need torque specs or engine specifications, let me know.
Take care and let me know what I can do to help.
Nov 10, 2021 at 10:35 AM
