Knocking sound when not accelerating or braking
204,000 MILES • V6 • 2WD • AUTOMATIC
DARIUS HOWANYK
So my car has been making a knocking sound that started around four days ago. It only happens after I release the accelerator pedal and increases the faster I go. It also goes away when I press on the brake.
Jun 20, 2019 at 1:38 AM
  • 110,251 POSTS
Welcome to 2CarPros.
Since it stops when there is pressure on the drive axles, I first recommend checking to make sure you don't have a bad CV joint (axle joint). Safely lift and support the front of the vehicle and inspect wheels for tightness, for excessive play in the axle shafts, check the steering components and wheel bearings. Make sure you don't have a loose caliper or caliper bolt missing. Here are a few links you may find helpful, and the more I think about it, the more I'm thinking you may even have a loose wheel. Make sure they are tight.
https://www.2carpros.com/articles/clicking-sound
https://www.2carpros.com/articles/popping-noise
Jun 20, 2019 at 12:11 PM
