Knocking sound
170,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
BW74
  • 50 POSTS
Front drivers side knocking sound going over bumps. Worse when colder out. Been to two mechanics who could not find anything.
Feb 27, 2018 at 9:02 PM
HARRY P
  • 2,292 POSTS
Likely cause is worn out struts at that age. If you have a floor jack, you can put it under the lower control arm and jack up the car a bit. Then you simply try to move the strut up and down. If it moves more than about 1/4 inch, it is bad. The guide below is about replacing the lower control arm, but it is useful in that it shows you what the control arm is.
https://www.2carpros.com/articles/lower-control-arm-bushing-replacement
Feb 27, 2018 at 9:15 PM
