Engine knocking sound
240,000 MILES • 4 CYL • 2WD • AUTOMATIC
CHRISTY MCCULLIGH
My car started making a knocking sound. I checked the oil nothing on the stick so I added oil noise stopped. then 2 days later started again, checked oil still full. there is no engine light on, there is no smoking, there is no loss of power and the knocking starts when you crank the car. while you are driving it will go in and out and when you come to a stop it will stop, but as soon as you push on the gas it starts knocking again. The engine has not shut off at all it cranks every time I start it. The oil light never came on it has not overheated I have had to change my brake pads 2 times in 6 months. I have had the car for 3 years and i have never changes spark plugs or wires and i have only done 2 oil changes.
Nov 8, 2020 at 10:00 AM
More then likely you have a bearing issue if it was knocking and you found no oil.
At this point we need to drain the oil into a clean pan and inspect it for metal shavings. If you find metal then more then likely it will need to be replaced or rebuilt
Also, can you get a recording of the noise? That will help us confirm this is what it is because a knocking engine has a distinct sound. Thanks
Nov 8, 2020 at 10:42 AM
