Knocking or grinding possibly from transmission
180,000 MILES • 4.9L • 6 CYL • 4WD • MANUAL
DALEG1980
  • 11 POSTS
First I replaced the clutch with clutch kit. Have new motor and transmission mounts. Replaced universals. So last couple weeks i have been getting this like knocking noise and i can feel it at my feet. The funny thing is that it does it when moving and at a full stop. I am thinking it may have something to do with a bearing. When the clutch is in neutral or in gear still makes that sort of knocking sound. At high speeds its very consistent and loud. When drifting down a hill in gear with clutch peddle down or neutral same sound. I have a hard time trying to catch the sound when parked but can't figure out where it is coming from, but it seems to be right at the oil pan and transmission. What could it possibly be?
Nov 6, 2019 at 10:45 AM
Good morning,
Can you upload a video of the noise so I can hear it?
This sounds like an internal engine noise.
Nov 6, 2019 at 5:33 PM
DALEG1980
  • 11 POSTS
I can never catch the sound when i get out it is luck of the draw. But to let you know it is not effecting the truck. Everything is still the same. Drives fine, runs fine, no bogging, or nothing. It's hard to explain it is like a faint knocking not like when oil runs out in motor. Almost sounds like grinding but only at times mainly at high speed. If you have questions please ask. Thanks.
Nov 6, 2019 at 11:24 PM
I understand but I still need to hear the noise. Why do you not just try to catch the noise when it is making it and record it for me to hear. Then I can advise you on the noise.
Nov 7, 2019 at 12:11 AM
DALEG1980
  • 11 POSTS
I will try to. It is a loud truck so i wouldn't be able to record it inside while driving. But as soon as i can hear the noise while at park. I will get it for ya. Thanks.
Nov 7, 2019 at 4:25 AM
You are welcome.
Keep us updated.
Nov 7, 2019 at 4:44 AM
DALEG1980
  • 11 POSTS
I'm sorry i just haven't been able to catch the sound. Truck has been down for three days. I had to replace front rotors and brakes and 4 wheel hub and inner seal. To cut down some of the noise. Now i need to replace both rear seals leaking gear oil out of the tires. I have a new question posted about the how to remove seals. As soon as i get it back on the road i will try to get the sound for ya.
Nov 14, 2019 at 8:46 AM
Sounds like a plan.
Nov 14, 2019 at 8:48 AM
