Knocking noise rod barring
209 MILES • 0.5L • AUTOMATIC
IRIS0808
It makes a knocking noise not sure where it's coming from friend says I blew a rod
Feb 12, 2016 at 9:32 AM
CATAFINA
  • 167 POSTS
Where's is it coming from lower or upper end of the engine
Feb 12, 2016 at 12:27 PM
HMAC300
  • 48,601 POSTS
if it's a rod knock sort out each cylinder one at a time as you disconnect spark plug wire the knocking should go away if it's a rod or piston. an upper end sound will be more of a ticking/light knock.
Feb 12, 2016 at 9:56 PM
