Knocking noise in engine, still drives fine, fluids are good maybe piston. Have a video I could forward.
Apr 11, 2017 at 10:28 AM
SCULLY
MEMBER
In Ann Arbor Michigan area.
Apr 11, 2017 at 11:15 AM
HMAC300
✓Experienced Mechanic
what is oil pressure? if low or light comes on may be a bearing. piston noise will normally be cold then when warm it goes away. videos will not do much good. you can try removing plug wires one at a time if knock goes away then it is that cylinder. pretty much have a local mechanic check it out.
