2007 Chrystler Aspen-when started there is a banging sound in the oil pan which continues when driving. The car can be driven for about 10-15 minutes before shutting off and will not start again until the engine is completely cooled off. I changed the air filter and oil and there was 20 quarts of oil that went nowhere however there are no oil leaks on the top or bottom of the motor. I was told this is a crankshaft and rod bearing issue and would like your advice.
Aug 24, 2014 at 9:09 AM
