knocking engine?
110,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
MOONECAT2015
I was driving and felt a wheel jersey to the left and then the engine started knocking loudly. Higher ram has a grind squeal added in. No engine check light. Is this rod knock, timing, lifters or a transmission issue?
Feb 5, 2023 at 6:32 AM
  • 110,248 POSTS
The noise could be any of the things you mentioned and more. However, I'm not sure what you mean by wheel jersey. Did you hit a Jersey Barrier?
As far as the noise, do me a favor and look through this link. Let me know if anything matches what you hear,
https://www.2carpros.com/articles/engine-noises
Also, if you could record and upload it for me to hear, that may help.
Feb 5, 2023 at 9:40 AM
