When selecting a gear there is a small knock sound, when the gear is selected and I take up drive there is a knock as well
25,000 MILES • 1.1L • 4 CYL • 2WD • MANUAL
MAX KELLY
Also, if I press the brake hard it knocks slightly. The steering is fine and has no play and the engine mounts are perfect. I was thinking it could be drive shafts. But I’m unsure and on a limited budget.
Apr 1, 2022 at 1:43 AM
  • 110,248 POSTS
This vehicle isn't offered in the US, but I will try my best to help.
First, is it loud enough for you to record and upload for me to hear? If it is, please do that so I can hear it.
Next, when a CV joint/axle fails, often times you will hear a clicking sound when turning or putting a load on it. Take a look through this link and see if it seems to mirror what you experience:
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
Also, have you checked to make sure there are no worn or broken bushings on the steering components or suspension components?
Apr 1, 2022 at 2:45 PM
