Knock when of full lock
100,000 MILES • 1.5L • 4 CYL • 2WD • MANUAL
ROHITSUK
The following parts were replaced after which a loud knock can be heard when going forward or reverse on full right or left lock after the car has been standing for a while but rarely when driving.
1. Front Shock Absorbers
2. Shock Absorber mounts
3. CV joints
4. Big Lower Arm Bushes
5. Small Lower Arm Bushes
6. Lower ball joints
7. Stabilizer Arm Links
Many thanks.
Dec 11, 2016 at 5:52 AM
JIS001
  • 3,412 POSTS
Try to put the vehicle over a pit. Have someone rock the vehicle side to side while you check the sway bar bushings. When they are worn out you will see the sway bar moving up and down and making a thumping noise.
Dec 11, 2016 at 7:40 AM
ROHITSUK
Thank you for your reply.Rohitsuk
Dec 11, 2016 at 11:33 AM
