knock sensor location
31,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
GORDY041
location for the knock sensors on the car listed above.
Jan 10, 2018 at 9:31 AM
HARRY P
  • 2,292 POSTS
This is what ALLData has on the 2.4L Hybrid Malibu knock sensor. The non-hybrid options are 2.0 and 2.5, so let me know if this is the right one or not.
Jan 10, 2018 at 10:33 AM
JUAN2345
knock sensors locations. there are two. thanks
Sep 7, 2020 at 7:10 AM (Merged)
  • 31,937 POSTS
See picture. item 5 should be the same other side of engine. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
14GREENEYES75
Where is the engine knock detonation sensor located on my Chevy Malibu 99. Thank u for your time and help.
WRENCHTECH
  • 20,760 POSTS
It's on the left side of the block, near the transmission. https://www.2carpros.com/images/external/86422029.jpg.gif
it is on the front of the motor lower side by the oil filter. there are 2 sensors there. one is the oil pressure sensor and the other is the knock sensor.
14GREENEYES75
Thank you so much for your time and help I will continue to contact u with any further questions. Thanks again.????
14GREENEYES75
Thank you really appreciate it.
