Knock sensor replacement
150,000 MILES • 3.3L • V6 • 2WD
DANBO46
  • 12 POSTS
The knock sensor is located under the intake manifold. Is there a better way to replace it without removing the intake manifold?
Dec 15, 2018 at 12:20 PM
  • 110,248 POSTS
Hi and thanks for using 2carpros.com.
I wish I had a better way, but the intake needs to be removed to replace it. It is mounted in the engine block below the intake. It calls for 4.2 hours labor, so it's not a quick fix.
Dec 15, 2018 at 1:20 PM
DANBO46
  • 12 POSTS
I purchased a new electric radiator fan it came with two wires a blue and a black.The connector has two blacks and a green with a black stripe, is it hooked up black to black and black to blue, if so where do I place the green with the black stripe?
Dec 16, 2018 at 10:48 AM
  • 110,248 POSTS
Hi and welcome back:
I'm sorry but I need you to start a new thread. The site owner wants each post to focus on one topic. Again, sorry. I will watch for you new post.
JOe
Dec 16, 2018 at 11:02 AM
