Knock sensor location?
147,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
KRISTIAN CHAVEZ
Where is knock sensor located?
Dec 18, 2024 at 1:48 PM
  • 55,770 POSTS
This engine has two knock sensors each on the lower part of the engine block on either side, right and left. Here is a diagram that shows the location of one, so the other is in the same place but the opposite side. Check out the images (below). Let us know if you need anything else.
Dec 19, 2024 at 3:57 AM
