Knock sensor code
112,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
DCANNON1390
  • 40 POSTS
A few months ago my water pump broke and I replaced and I replaced it with regular coolant instead of DeXcool coolant. I now have a knock sensor code. Could that be the reason? If not then what could it be?
Jun 21, 2020 at 5:14 AM
Good afternoon.
No to the coolant causing the issue.
Can I have the code number that was set so I can look it up?
https://www.2carpros.com/articles/how-a-knock-sensor-works
Jun 21, 2020 at 5:53 AM
DCANNON1390
  • 40 POSTS
P0332.
Jun 21, 2020 at 6:39 AM
DCANNON1390
  • 40 POSTS
Should I still drain the coolant and put dexcool in or will it be fine?
Jun 21, 2020 at 6:40 AM
I found a TSB for the code that recommends replacing the sensors and the harness.
did you replace the harness when you did the sensors?
File In Section: 06 - Engine/propulsion System
Bulletin No.: 02-06-04-023
Date: May, 2002
TECHNICAL
Subject:
Audible Spark Knock (Detonation), MIL Illuminated, DTC P0332 Set (Replace Rear Bank Knock Sensor and RTV Area Around Sensor)
Models:
1998-2002 Chevrolet Camaro, Corvette
1998-2002 Pontiac Firebird with 5.7L Engine (VIN G - RPO LS1)
1999-2002 Chevrolet and GMC C/K Pickup and Utility Models (Avalanche, Silverado, Sierra, Tahoe, Suburban, Yukon, Yukon XL, Yukon Denali, Yukon Denali XL)
with 4.8L, 5.3L or 6.0L Engine
(VINs V, T, Z, N, U - RPOs LR4, LM7, L59, L09, LQ4)
Condition
Some customers may comment on a mild to severe engine ping (commonly referred to as spark knock), usually worse during acceleration and/or an illuminated MIL. Upon investigation, the technician may find DTC P0332 set.
Cause
This condition may be the result of corrosion of the rear bank knock sensor due to water intrusion into the sensor cavity. This condition is more apparent on vehicles in which customers frequently wash the engine compartment.
Correction
Replace the rear bank knock sensor and build a dam (wall) around the sensor using RTV to divert water away from the sensor. Use the procedure and part number listed below.
1. Remove the intake manifold. Refer to the Intake Manifold Replacement procedure in the Engine Controls sub-section of the appropriate Service Manual.
2. Remove the wiring harness assembly from the knock sensor.
3. Remove the rear bank knock sensor.
4. Install the new rear bank knock sensor.
Tighten
Tighten the knock sensor to 20 N.m (15 lb ft).
5. Install the wiring harness assembly to the knock sensor.
6. Apply a bead of RTV silicone sealant approximately 9 mm (3/8 in) wide and 6 mm (1/4 in) high along the outside edge of the ridge on the engine block valley cover around the rear bank knock sensor. DO NOT form a complete circle. Leave the rear section open as shown.
7. From the underside of the intake manifold, completely remove the rear intake manifold seal (foam material).
8. Install the intake manifold. Refer to the Intake Manifold Replacement procedure in the Engine Controls sub-section of the appropriate Service Manual.
Jun 21, 2020 at 6:51 AM
DCANNON1390
  • 40 POSTS
Okay. I'll replace it and tell you if it works.
Jun 21, 2020 at 7:08 AM
Sounds like a plan.
Keep us updated.
Jun 21, 2020 at 7:09 AM
DCANNON1390
  • 40 POSTS
Would a rear differential from a 2003 Avalanche fit on a 2002 Sierra?
Jun 22, 2020 at 10:09 AM
We are talking another issue. We can only deal with one issue per question. that is the site rules.
You need to start another question from the beginning.
www.2carpros.com/question/new
Jun 22, 2020 at 10:12 AM
DCANNON1390
  • 40 POSTS
Okay.
Jun 22, 2020 at 10:18 AM
