Knock sensor?
75,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
JUSTIN MARSEE
Changed the knock sensor 2 times now and the pigtail as well. It runs good for about 1 hour, then the light comes back on and the same code knock sensor #1. Bank 1 knock sensor.
Feb 7, 2023 at 10:17 PM
  • 110,246 POSTS
When you installed the sensors, did you torque them to specification? Also, could you provide me with the code you are getting so I can specifically check what may be the cause?
Feb 8, 2023 at 6:07 AM
