Knock sensor location needed
165,000 MILES • 4.6L • 4WD • AUTOMATIC
PETE DURKIN
How do I locate (Bank 1) knock sensor? Car listed above has a 4.6 Northstar.
Mar 23, 2021 at 4:19 AM
  • 110,246 POSTS
To access the knock sensor, you need to remove the intake manifold. Also, there are two knock sensors. If you look at the first picture below, I highlighted the bank one knock sensor.
You will need to remove the intake manifold. The pics below (starting with pic 2) are the directions and pictures for the removal and replacement of the intake.
I hope this helps. Let me know if you have other questions.
See pics below
Mar 23, 2021 at 12:44 PM
PETE DURKIN
Thank you so much! Looks like I’ll be busy on Saturday! Thanks again Joe!
Mar 23, 2021 at 12:53 PM
  • 110,246 POSTS
You're very welcome. Let me know how it turns out for you. Also, let me know if you have other questions.
Mar 24, 2021 at 10:35 AM
