Where is the knock sensor located on the block? Thanks in advance
Sep 24, 2026 at 5:32 PM
MECHTRIX
✓Experienced Mechanic
It sits between cylinders 2 and 3 on the block hiding under the intake manifold to the best of my knowlage ...good luck hope this helps .
Sep 25, 2026 at 11:01 AM
MECHTRIX
A Quick side note"
Its In the center of the block its held by a single bolt uses a 10 mm wrench or socket good luck .
Sep 25, 2026 at 11:07 AM
REVJIM64
MEMBER
So I take it that I have to go from there bottom. Is there any diagram of it? Thanks a lot
Sep 25, 2026 at 5:02 PM
MECHTRIX
They say the intake manifold requires removal on that vehicle ..id say try to locate it first ot sure if you be able to see it ..but maybe with a mirror becuase its suposed to be directly underneath the intake manifold ...just be be clear its the knock sensor you looking fir right ? Not the cranks sensor ?
