Where is the Knock Sensor located?
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
DRHANNES
I have a check engine code for the knock sensor. Where is the knock sensor for replacement?
Aug 6, 2025 at 6:20 PM
MECHTRIX
  • 583 POSTS
Screwed into the side of the engine block under the intake manifold good luck
Aug 7, 2025 at 3:52 AM
  • 55,694 POSTS
Yep, MECHTRIX is correct, here is the location. Check out the images (below). Let us know how it goes.
Aug 8, 2025 at 10:31 AM
