Engine shut off while driving
170,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
RUDEBOI556
Okay, I have the vehicle listed above. I was riding down the highway and all of a sudden it shuts off the only thing out of place is a knock sensor by the distributor. can that keep my car from cranking it will turn over?
Apr 1, 2021 at 4:53 AM
  • 110,248 POSTS
The knock sensor is used to fine-tune ignition timing. It shouldn't prevent it from starting.
I need you to do a couple of checks. Chances are you either lost fuel pressure or spark to the spark plugs. Here are two links that show how to test for both:
I need you to check for both of those. Also, here is a link you may find of interest. It discusses the most common causes of a crank no start condition:
Apr 1, 2021 at 1:10 PM
