Knock sensor having an issue finding the hole to screw the bolt back on the knock sensor that is supposed to be located on the back of the engine block somewhere?
172,363 MILES • 4.2L • V6 • 4WD • MANUAL
DWRECK
Hi, I'm having an issue finding the hole to screw the bolt back on the knock sensor that is supposed to be located on the back of the engine block somewhere? I accidentally took it off when and didn't need to when I was changing my lower and upper intake manifold gaskets. The back of the engine is very dirty, and I've tried wiping it off the best i can but still no luck finding the hole to put knock sensor back on truck.
I'm using a mirror and super bright lights but still can't find it. I see plenty of holes on the back of the lower intake manifold, but none are the ones I need. I've searched and searched online/ YouTube and am getting different answers for different locations on back of block. If you have anything that would help me, I would greatly appreciate it so I can get my truck back on the road ASAP. Thanks
Dec 26, 2024 at 7:07 AM
  • 110,248 POSTS
It should be at the rear, driver's side of the engine. I attached a picture below from my manual that shows its location.
Take a look at the picture and let me know if this helps.
joe
See pic below.
Dec 26, 2024 at 2:39 PM
DWRECK
I appreciate it. I found it easily after you sent the picture of the location. I had to of found every other hole in the back besides that one lol. Thanks
Dec 27, 2024 at 3:21 AM
  • 110,248 POSTS
I'm glad it helped, and you are very welcome.
Take care and feel free to come back anytime in the future.
Dec 28, 2024 at 12:56 PM
