knock sensor
160,000 MILES
PIRSQ
Can you tell me the location fo the knock sensor? I have the base model with a 4 cylinder engine. The diagnostic codes were P0325 and P0327 which indicate a Knock Sensor circuit low input and circuit bank. I can not find the location of the sensor in order to replace it. An image would be most helpful.
May 26, 2013 at 5:53 AM
HMAC300
  • 48,601 POSTS
The knock sensor is located in the engine block above the starter, item 8 in drawing.
May 26, 2013 at 11:17 PM
