Broke camshaft, replaced with a 3.4L Pontiac Grand am engine, 1999 as well, but with A.I.R. system in heads. Only one way check valves left. So, after replacing a lot of stuff, catalytic converter, EGR, EGR line, oil pan gasket, etc. Was ready, took it out for a test drive. Family was happy, as we had this sitting around, and I decided to use it as a learning experience for the family.
So, everything went quite well, ran nicely. Went up a hill, felt and heard a pop noise. Pulled over, knocking sound. Drove it short distance home. Checked out engine, assumed rod/main bearing. Just went to troubleshoot, and it knocks at idle, less with serpentine off. Hit throttle, and over 1,000 rpm's or so, goes away. Pulled every plug wire, makes noise worse. Noticed a small liquid spray shooting from EGR line to EGR valve. Thinking heads/valves, not quite real sure.
This is a learning experience car, so not real interested in "just get rid of it" answers. I am stumped at where to troubleshoot the problem, and would like to teach my wife and kids how to disassemble/reassemble, or why it is better to try another boneyard engine.
Nov 19, 2017 at 1:27 AM
