Codes P0405, P1516, and P2101, knock in top end?
140,000 MILES • 3.4L • 6 CYL • AUTOMATIC
ED&DESI
We replaced the rocker arms and lifters changed oil and filter it still has knock in the top end but drives fine. The codes that come up are P0405 P1516 and P2101, what else could be the problem?
Aug 10, 2023 at 10:48 AM
  • 55,594 POSTS
It sounds like you may have carbon on top of a piston which is common, if you upload a short video of the noise I can tell for sure. Please go over this guide
https://www.2carpros.com/articles/understanding-and-repairing-engine-knocking-noise-an-in-depth-guide
P0405 - Exhaust Gas Recirculation (EGR) Sensor A Circuit Low:
P1516 - Throttle Actuator Control (TAC) Module Throttle Actuator Position
P2101 - Throttle Actuator Control Motor Circuit Range/Performance:
None of these codes will create an engine knocking sound. Please upload pictures or videos of the problem so we can see what's going on.
Aug 11, 2023 at 4:43 AM
ED&DESI
That is with the back value cover off.
Aug 11, 2023 at 7:39 AM
  • 55,594 POSTS
It looks like the spark plug wires could have been installed incorrectly. Can we please double check it?
Firing Order .................... 1 - 2 - 3 - 4 - 5 - 6
Aug 12, 2023 at 2:16 AM
ED&DESI
They are In the right place.
Aug 12, 2023 at 5:33 AM
  • 55,594 POSTS
You might have a head gasket blown between two cylinders, let's do a compression test to see what's going on.
Please go over this guide and get back to us.
Aug 14, 2023 at 3:53 AM
