Code P0325 keeps coming up
147,000 MILES • 2.0L • V6 • 4WD • AUTOMATIC
MANOAMBU
  • 12 POSTS
The check engine light was on. went to AutoZone and pulled codes P0330 and P0325. Went to mechanic , confirmed bad Knock Sensor, replaced them. After sixty miles the check engine light came on and code pulled P0325. Went back to mechanic and replaced Knock Sensor Bank 1 Circuit 1. after driving three miles check engine light came on, pulled Code P0325. Do not know what to do? Already spent few hundred dollars. Is is advisable to go somewhere else which means more money from scatch or live with it until Inspection next month?
Apr 17, 2019 at 10:39 AM
  • 110,246 POSTS
Welcome to 2CarPros.
The knock sensor is responsible for fine tuning ignition timing. If you are not hearing any valve tapping or engine noise, you should be okay to drive it, but if you do hear engine noise, I wouldn't want to drive it. It could cause other damage.
Here is a link that explains how one works:
https://www.2carpros.com/articles/how-a-knock-sensor-works
As far as the problem, if the sensor was replaced, chances are there is a short in the wiring or a bad connection. I will provide the diagnostics for the issue, but it will require some special tooling. The basic testing equipment I will provide links explaining how to use them.
_________________________________________
Here are the directions. All attached pics correlate with these directions.
Troubleshooting
Vehicle ALL Diagnostic Trouble Codes ( DTC ) Testing and Inspection P Code Charts P0325 Troubleshooting
TROUBLESHOOTING
CIRCUIT DESCRIPTION
Each of knock sensor is fitted to the right bank and left bank of the cylinder block to detect engine knocking. This sensor contains a piezoelectric element which generates a voltage when it becomes deformed, which occurs when the cylinder block vibrates due to knocking. If engine knocking occurs, ignition timing is retarded to suppress it.
picture 1
DETECTING CONDITION
If the ECM detects the above diagnosis conditions, it operates the fail-safe function in which the corrective retard angle value is set to the maximum value.
picture 2
WIRING DIAGRAM
Step 1
picture 3
Step 2
picture 4
Step 3
picture 5
INSPECTION PROCEDURE
HINT:
- DTC P0325 is for the right bank knock sensor circuit.
- Read freeze frame data using LEXUS hand-held tester or OBD II scan tool. Because freeze frame records the engine conditions when the malfunction is detected. When troubleshooting, it is useful for determining whether the vehicle was running or stopped, the engine was warmed up or not, the air-fuel ratio was lean or rich, etc. at the time of the malfunction.
________________________________________________
Here are a few links that you may find helpful:
Let me know if this helps.
Apr 17, 2019 at 12:53 PM
JIS001
  • 3,412 POSTS
Did you replace both knock sensors? Maybe the wrong was replaced. Also if the replacement knock sensor was dropped accidentally then it would make it no good? What brand sensor did they put on as well? There are certain brands that are just junk. Let us know please.
Apr 17, 2019 at 4:33 PM
MANOAMBU
  • 12 POSTS
The Brand is Standard Products Knock sensor KST159. I was there when he changed it and did not drop it. But i did not see him replace the Wiring Harness. But the car is running smooth. I saw in Lexus Owners Forum there is a way to bypass the P0325 wiring and splice it with P0330 wiring through the glove box. Is it true and does it work?
Apr 17, 2019 at 10:08 PM
  • 110,246 POSTS
Welcome back:
The brand is good, but were both replaced? Also, I never heard of splicing wiring to get rid of a code. Honestly, I wouldn't do it.
Let us know.
Apr 18, 2019 at 1:06 PM
MANOAMBU
  • 12 POSTS
i went back to the mechanic and asked him to replace the wiring harness. He could not locate one from after market.He told me that one wire was broken and he soldered it. Then i ordered a wiring harness (Lexus part # 82219-07010) and will take it back to him to install in my car. I have a feeling if he found one broken wire there may be other wires broken in the harness. Hopefully this will solve the problem. I will get back to you on Monday.
Apr 18, 2019 at 1:13 PM
  • 110,246 POSTS
Welcome back:
I agree. If one was broken, there could be others. I will watch for your reply.
Apr 18, 2019 at 1:18 PM
MANOAMBU
  • 12 POSTS
Thanks Joe,
I will get back to u on Monday.
If i clear the CEL code by Code Scanner and if I go for inspection will the Inspector's Scanner be able to read the Knock Sensor code? The car is running smooth and I wont be able to drive if it does not pass inspection. This is a problem for lot of older cars. And you have to spend lot of money to remove these codes. Sometimes the codes can malfuntion too?
Apr 19, 2019 at 1:16 AM
  • 110,246 POSTS
Welcome back:
I'm in PA and can tell you I know when codes were reset. When doing an emissions inspection, the first thing I do is check to see if all monitored systems indicate complete. I will try to explain. When you clear codes, you basically erase everything. Then, you need to complete drive cycles for the component monitors to reset. If they are not reset, the scanner or emissions machine will reject it. Now, here is the catch 22. By the time everything resets and it is ready for the test, the check engine light will return indicating the problem is still there. Once the specific monitored system resets that is turning the light on, again the light will return.
I hope that makes sense. Sometimes the easiest things to explain see the most difficult.
Let me know if that helps and if you have other questions.
Apr 19, 2019 at 12:14 PM
MANOAMBU
  • 12 POSTS
Thanks Joe,
u are 100% correct. In the good old days I remember when the cars did not have computers it was common practice to remove the battery terminal and pass inspection. But now almost every car has a computer and after removing the battery terminal u have to drive the car certain miles to get the history back into the computer.
I got the Knock Sensor Harness for my Lexus. Monday my Mechanic will install it. I am keeping my fingers crossed. If the Knock Sensor code comes again i do not know what to do? Then it means that the wiring could be wrong and that could be any wire. It is going to be a Herculean Task. I see some Auto Shops with signs `Auto Electric Repair'. Maybe I should go to them. By any chance do u know any reliable Auto Electric Repair shops in Bergen County NJ? I will get back to u Monday night. Meanwhile Happy Easter to U and ur family.
Sam
Apr 20, 2019 at 10:53 AM
  • 110,246 POSTS
Welcome back, Sam.
Honestly, I don't know of anyone in that area. I'm about an hour outside of Pittsburgh. As far as the issue, if this doesn't fix it, it could be related to the PCM. However, lets not think of that until we see if the problem is resolved. I will keep my fingers crossed.
Take care and I will watch for your reply on Monday.
Apr 20, 2019 at 12:15 PM
MANOAMBU
  • 12 POSTS
Today the mechanic replaced the Wiring Harness and the check engine light came within a mile. I went back to him and he had an electrical technician(a young kid) who joined his shop recently connected a device to the car and monitored it on the computer for about half hour and came and told me is is a Temperature Sensor in the circuit of Bank 1(maybe he meant Oxygen Sensor). Then he shook the outlet manifold of Bank1 and the check engine light went out. He told me that it is the problem and I wont get it again. After driving the car for about ten miles the dreadful check engine light came back again. I was very frustrated. Went straight to AutoZone and got the reading as follows:
P0171-System too lean (Bank i)
P0325- Knock Sensor 1 circuit (Bank i)
P0171-System too lean (Bank 1).
And the Print out recommends to replace AIR/FUEL Ratio Sensor (AFR). Is it the same as Oxygen Sensor?
The Technician in AutoZone told me it is most probably the Oxygen Sensor in Bank 1 and cost about $150.00. I do not know what to do. I have invested too much money in this car to dump it. For trade in I may get maybe $2,000.00. But i have spent almost double in this car. But the car runs very good, picks up good and everything. But without passing inspection in NJ it is useless. Consistently the fault is in Bank 1. I have changed the knock sensor and the harness and so I think the only option is to change the Oxygen Sensor and see. Is there any other Sensor in Bank 1? Thanks for trying to help me.
Sam
Apr 22, 2019 at 9:33 AM
  • 110,246 POSTS
Sam:
The reading indicates a lean mixture which usually isn't the oxygen sensor. The tech that watched how the vehicle was responding should be able to see how the o2 sensor is responding. Most times, there is an engine vacuum leak or even an exhaust manifold leak allowing unmetered air to get into the bank one system. Is it possible for you to have him scan the sensor to see if it is responding before you get a sensor?
Also, most times a sensor goes bad, the computer over compensates fuel mixture which would cause the opposite, a rich mixture. Before you purchase a sensor, see if you can have that done and let me know the results.
Okay, I'm going to get a bit technical so you know exactly what to ask for if you take it in. If there is something I say you don't understand, let me know.
Anytime there is a driveability issue, the first things to check are short-term fuel trim (STFT) and long-term fuel trim (LTFT). Fuel trim is an extremely important and a key diagnostic parameter which is helpful in many ways. It tells the tech what the computer is doing to control fuel delivery. STFT and LTFT are shown as a percentage. In a perfect world, you want the range being within 5% of 0. The 5% can be positive or negative, but that is normal. When it exceeds that, then questions come up. Positive fuel trim percentages indicate that PCM is adding fuel to the fuel mixture to compensate for a lean condition. Negative fuel trim indicates the PCM is trying to lean the fuel mixture to compensate for a rich condition. With that in mind, you should see a negative STFT beyond 5%.
Now, If I know what the SHFT and LTFT are, that will help me to determine the next issue.
Now for the O2 sensor. Testing O2 sensors is simple. The sensor needs to exceed .8 volt and drop below .2 volt. The change from low to high and opposite should be quick. Most times, a good snap throttle test will verify the sensor’s ability to achieve the .8 and .2 voltage limits. If the sensor doesn't react in that manner, it most likely is bad. Also, the high output should be when the fuel mixture is richest (when you snap the throttle). Once the throttle is released, it should snap back to the low voltage.
If the sensor seems non responsive, confirm there are no wiring issues and if not, replace it. Also, if it remains at a high voltage reading, create an engine vacuum leak to see if that changes how it responds. If it is showing lean and doesn't change, you can actually use propane to create a rich mixture, but I don't want you doing that.
________________
Why did I ask for the fuel trims and to see how the sensor is reacting? Between the two, I will be able to tell if the computer is doing what it needs to do and if the sensor is actually faulty. I'm hope you understand this. I'm trying to focus on what is showing as the problem now and to determine if it is the sensor or not. I know what another $150.00 is like. Especially when it gets spent unnecessarily.
______________
Please feel free to let me know if you have questions or need clarification. Also, let me know what you decide.
Apr 22, 2019 at 11:29 AM
MANOAMBU
  • 12 POSTS
did you read my response? Anyhow I will give you what happened. I went to another mechanic who seems to know what is happening. He drove the car and then changed the Bank 1 A/F sensor. Then drove the car again on a highway for ten miles. CEL came after one mil. But he was reading the Diagnostic machine all the time while driving. Then told me that there are leaks in the exhaust system and wanted me to fix it. Today I went to my Muffler guy and he replaced portions of the Muffler pipe and made sure there are no leaks. Then he did the smoke test and found one hose was not connected and connected it. When i drove it home the CEL came after 2 miles. I went to AutoZone and codes P0325, P1130 and P1150 pulled out. The two latter codes are sensors 1 on Banks 1 & 2. I just replaced the A/F sensor on Bank 2 Sensor 1. I also replaced the Knock sensor on Bank 2 two times. This shows that the computer is getting wrong info from the sensors.So I have to take to the young mechanic Monday for more tests. I am getting frustrated and ready to give up. Any input will be appreciated.
Apr 26, 2019 at 9:07 AM
  • 110,246 POSTS
Welcome back:
I didn't see a prior post. Honestly, did the exhaust repair shop check the exhaust manifold for leaks? In my last post, I indicated a vacuum or even an exhaust leak. Now, however, it seems there are new problems.
Since one of the Air/Fuel Ratio sensors was replaced and now they are both showing up, the first thing I would check is what voltage is being indicated from the AFR sensors. Using a live data scanner, you need to check for output voltage from the sensors. With the engine warmed up, the voltage should be between 2.8v and 3.8v. If it goes above that or below, it will set the codes you have.
These codes weren't present before, correct? If they weren't, check the connection to both sensors. Make sure nothing is melted as far as wiring.
Apr 26, 2019 at 1:02 PM
MANOAMBU
  • 12 POSTS
Went to a muffler shop and replaced portions of muffler pipe and buttoned up the whole exhaust system. He checked for leaks with a nozzle and conformed no leaks. WEnt back to the mechanic and he checked and found one hose was broken and replaced. He also found a wire hanging and connected to the transmission connection. Then went for a ride and CEL came within a couple of miles and the mechanic was monitoring it while driving. He pulled up P0325 code.Autozone also pulledup P0325. No Oxygen Sensor codes. We know we replaced Knock Sensor on Bank 1 twice. He said he will check the wires by a voltmeter or ampere meter (I dont know). If that comes out OK then the mechanic said it could be the computer ECU. I dont know. Tomorrow is the day. If it happens to be the ECM i am done because it cost a couple of thousand dollars. But people say ECM does not go bad. I'll keep my fingers crossed!!!
Apr 30, 2019 at 11:52 AM
  • 110,246 POSTS
Welcome back:
I too will keep my fingers crossed. As far as the PCM, they do go bad. However, most times it is a wiring issue after the PCM or a bad connection at the PCM due to corrosion or a damaged wire. Just based on the sensor's location, wiring could be an issue due to heat. I attached a pic of sensor location in case you weren't sure where it is located.
Let me know what is found.
Apr 30, 2019 at 12:15 PM
MANOAMBU
  • 12 POSTS
Thanks Joe. I went back to the same mechanic and they have a young guy supposed to be an Auto Electric Maven. He checked all wiring including the wiring at the back of the Glove Box. He worked on it for an hour. THen he put everything back and told me that the Wiring Harness between the two Knock Sensors had a problem and said that he fixed it. From the way he replied me I knew that he was not sure. I took the car back to my home and within a mile CEL came. I went to Autozone and asked them to pull the code. the reading said `Code P0325 indicates a fault in the Bank 1 Knock Sensor1 electrical circuit for a predetermined period of time'. I do not understand what is meant by `PREDETERMINED PERIOD OF TIME'. Now I am going to another Mechanic who said he will try all ways to fix it. He did find some hoses frayed/cut and replaced them before. He also said that there is a possibility that CEM could be wrong and they sell them in Ebay which can be purchased and reprogrammed to the vehicle (CEM from Lexus is like $2300). THe car runs good and I fixed the muffler and all the brakes and so it is very hard for me to trade it in or sell it for a cheaper price. I think the car has about another 5 years left, maybe more. The present milege is 148,000. I bought this 2000 RX 300 in 2003. Please comment.
Sam
May 2, 2019 at 11:15 AM
  • 110,246 POSTS
Welcome back:
Wow, I'm not sure what to tell you. You may be better off at this point to take it to a dealer.
What I have done is provide the diagnostic instructions in pic 1. It may help you or the person you are taking it to. The second picture shows the plug connector to the sensor.
Let me know if this helps at all.
May 2, 2019 at 1:06 PM
MANOAMBU
  • 12 POSTS
Thanks Joe,
In fact I took to Lexus and they checked (For $160) it and came back with the Knock Sensor codes and recommended to change both the Knock Sensors with the wiring harness and wanted $800. They also said that a hose connecting the Thermostat is leaking and wanted to replace it. I dont know if this will throw the Knock Sensor Code? I know I have replaced both the Knock Sensors (Bank 1 two times) and Lexus supplied Harness. THe Knock Sensors are Standard Product (Reputable Co.) If in case I let them change it , they will come back and say they will have to investigate the wiring and come up with even a bigger bill ($150/hour). I might as well buy a used American Car for that. I never had this kind of problem in any car I had. I had more than 12 cars in my life, both American and Japanese.
Today the young independent mechanic is checking my car for the CEL. I hope he finds and fixes the problem.I will show him ur instructions. By the way, the picture in ur reply is it a scanning tool or a part in the car and if so where is it located?
Please reply and I'll keep u posted.
I found a website `Your Mechanic' and they say they will check the car in your driveway and diagnose for 79.99 and give a free estimate to fix the problem. Have u heard about this group? and if so are they reliable?
May 3, 2019 at 3:54 AM
JIS001
  • 3,412 POSTS
You could still have a defective part. Sometimes going OEM is better. Explain to the dealership you have already replaced all those parts and see what they tell you.
May 3, 2019 at 2:06 PM
MANOAMBU
  • 12 POSTS
Hi Joe,
Finally the sun shined on my car! I took it to the young Honduran Mechanic Wilson and left the car with him. The next day when I went to him he already opened up the engine and showed me Knock Sensor on Bank1 which looked bad. He replaced it with Denso Sensor. Then he proceeded to check all the wiring going to CEM. He told me the the module in the CEM controlling the KNock Sensors was bad and had to buy it and replace it. After a little while he called me and said he has corrected the wiring and the check engine light is gone. Then he himself took it to the Inspection Station and got a new Sticker good for two years. He charged me $400.00 which I know is cheap. For similar work I paid $650.00 which did not solve the problem. Thank God my nightmare is over. From now on Wilson is my Mechanic. He knows all aspects of the car and will fix anything. Thanks again to you for sticking with me giving me advice. I appreciate it very much. My name is Sam.
Sam
May 9, 2019 at 6:56 AM
  • 110,246 POSTS
Welcome back, Sam.
I'm glad to hear it is fixed and I'm happy to help. However, didn't they replace the knock sensor prior?
You know, today's mechanics can't just turn a wrench. They need to be able to analyze, diagnose, and think. I'm really glad to hear you found someone. And the price, $400.00 for parts and labor is good.
Take care and feel free to come back any time you need anything.
May 9, 2019 at 11:12 AM
MANOAMBU
  • 12 POSTS
Thanks Joe,
Yes, the Knock Sensor on Bank1 was replaced twice with standard product, manufacturer. The final one was Denso, which Toyota and Lexus uses on its cars. Probably the standard product sensor was bad. Anyhow I am happy now and hopefully this problem will not come again. Thanks for all the help and say Happy Mothers day to your mother and wife. So long.
Sam
PS: If i want to communicate with you in the future after a few months can I use the same link? `2carpros'
May 11, 2019 at 1:30 AM
  • 110,246 POSTS
Sam:
You are always welcome to come back. The only thing is we try to keep different conditions specific to one thread. It helps others with similar issues.
Regardless, you are welcome back any time.
Take care and best wishes.
May 11, 2019 at 11:56 AM
KEVIN BARTSCH
where the guy get the denso sensor that worked. Most all the ones I see online are fakes or people say wont work
Nov 18, 2019 at 4:53 PM
  • 110,246 POSTS
When getting things online, they may not be exactly what is described. I would suggest a reputable parts store.
Nov 20, 2019 at 6:37 AM
JEWLEZ N PELON GOMEZ
what type of fuel are you using ? I'm having same problem and check engine came on after replacing code P0330 and adding 87 fuel . and my vehicle is a 2002 es300 and recommends 91.
Mar 14, 2020 at 2:00 PM
  • 110,246 POSTS
The code you have, P0330, deals with the knock sensor. Have you replaced the sensor? If so, has the same code come back?
As far as using 87 octane fuel, you are more likely to have spark knock or detonation. The engine is designed to run on a specific type of fuel. Have you tried using 91 or higher octane?
Mar 15, 2020 at 10:00 AM
