First of all the wiring harness was damaged melted and the blower motor was burned out. After replacing the harness and blower motor I noticed that the blower motor stayed on after I removed key from the ignition. I tried to disconnect the resistor yet it remained on. I also removed the two relays one at a time but it remained on. I believe this is the reason it went bad in the first place and I am baffled why it stays on even if I remove the relays ( one is an a/c fan relay).
Jan 19, 2015 at 12:20 AM
