2008 Kia Sportage Possible Fuel Injection Problem
26,000 MILES • 4 CYL • FWD • AUTOMATIC
MIZDRAGON
When I started up my SUV this evening, it took much longer than usual to actually start. Once I got it running, it felt and sounded as though it was hesitating every 5-10 seconds or so. When I pressed the accelerator, it felt worse, and was much more audible. Might this be an issue with the fuel injection system?
Sep 13, 2009 at 10:59 AM
  • 110,248 POSTS
Have you checked fuel pump pressure? Here is a how to. My biggest concern is what is called "Fuel Pressure Drop Off." What happens is when the power is shut at the key, the fuel system looses pressure and which requires the pump to rebuild after you turn it back on.
Her is a how to for checking:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Oct 14, 2009 at 6:48 AM
