2002 Kia Sportage Runs Hot at Stop lights
105,000 MILES • 4 CYL • 2WD • AUTOMATIC
MAMMOTH
My air conditioner runs cool when driver at moderate speeds but when I stop at lights it blows warm air.
What could be the problem?
Thanks
Mar 29, 2010 at 8:28 AM
VAJACKSON
is it just your air conditioner or is the engine also running hot at stops??? I had a similar problem but it turned out that the fan that cools the engine was not working right all the time. Check the temperature dial when this happens. If it is going up at the same time you notice the change, this could be the problem.
May 20, 2010 at 12:13 AM
