Is it just your air conditioner or is the engine also running hot at stops? I had a similar problem but it turned out that the fan that cools the engine was not working right all the time. Check the temperature dial when this happens. If it is going up at the same time you notice the change, this could be the problem.
SPONSORED LINKS
Thursday, May 20th, 2010 AT 7:13 AM
