2002 Kia Sportage Rear Brakes
74,000 MILES • 4 CYL • 2WD • AUTOMATIC
SCOTTAUNGER
I need help figuring out how to get the rear drum off. I can not find an adjustment screw to lossen the shoes.
Aug 21, 2010 at 3:58 AM
BLUELIGHTNIN6
  • 16,542 POSTS
make sure you have loosened the 4 hub nuts and screws, shown below. once removed ensure park brake is off then drum should slide off, may have to bang on it with rubber mallet a few times in between studs.
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_735.jpg
Oct 16, 2010 at 10:22 AM
