2001 Kia Sportage Starts Vibrating after 60km/h
2001 KIA SPORTAGE
150,000 MILES • 4 CYL • 4WD • MANUAL
ROCKYBANSAL
I just started to get this vibrating problem in my car. As soon as I get over 60, it starts vibrating, otherwise its running smooth with no noise, if I am below 60. I checked the engine while it is parked and no matter if I press the gas paddle all the way down, the engine doesn't make no vibrating. The whole car only vibrates, when I am driving over 60. I would really appreciate, if someone could help me, before I take it to any mechanic. So atleast I am aware of something I dont know. I already spend a little too much for this year, So i am hoping to get some help from you. Thanks for your time and consideration. Or you can email me at rockybansal@hotmail.com.
Regards,
Rocky B
Dec 19, 2007 at 11:17 PM
BMRFIXIT
  • 19,053 POSTS
[quote:1f3c6f308f="rockybansal"]Other Category problem
2001 Kia Sportage 4 cyl Four Wheel Drive Manual 150000 miles
Regards,
Rocky B[/quote:1f3c6f308f]
have tires checked
also check the balance
check drive shaft and u joints
Dec 31, 2007 at 8:29 AM
ARTMANG
  • 61 POSTS
sounds like you need the the front tires to be balanced.when tires need balance the car shakes at certain speeds then if u slow it down they stop shacking.take the car to a wheel shop and have the front tires checked and rims balanced.front ones .
Jan 2, 2008 at 1:58 PM
