2001 Kia Sportage fuel pump
HERBSTER
Electrical problem
2001 Kia Sportage 4 cyl Four Wheel Drive Automatic
No-fire.. to the fuel pump.I have one hot wire going to the fuel pump relay I have one hot with the switch on but I do not have juice going to the fuel pump when I have the switch on or cranking it over.
I have checked the wire from the fuel pump up to the relay.The wire is good.What would cause the relay not to put fire back to fuel pump?What should I check next?
Feb 12, 2010 at 1:45 PM
  • 75,988 POSTS
Check the fuel pump fuse 10amp and inj fuse 30amp-and get back
Feb 12, 2010 at 7:06 PM
HERBSTER
i have checked all the fuses .u have3 blades top to bottom. 2 side to side center the top virticle blade is hot all the time the left virt blade is hot when the switch is on .the 2 center horzontal must go to fuel pump because if i touch my test light to the right virt blade i get power to the fuel pump wire .all this was done with the cover off of the relay i forget to say . with the switch on i have fire to the bottom blade that goes to wire going to the fuel pump but it does not light it up untill u touch thetest light to the right side virt blade .relay clicks then u have fire to pump
Feb 13, 2010 at 12:01 AM
  • 75,988 POSTS
Check the computer controlled of the fuel pump relay circuit-
Feb 13, 2010 at 6:56 AM
