2001 Kia Sportage fuel problem
2001 KIA SPORTAGE
110,000 MILES • 4 CYL • 4WD • MANUAL
ROYJ
my kia would not start i thought it was my fuel pump replaced pump it ran for 2 day but was hard to start now it want start
Feb 25, 2010 at 2:32 PM
This time no replacement of nothing do below to confirm it if its fuel or spark problem
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Feb 25, 2010 at 6:32 PM
