2000 Kia Sportage Water Pump
16,700 MILES • 4 CYL • 2WD • AUTOMATIC
REDKIA4ME1
My Kia is making a grinding noise under the hood. My heat is also not working. I had my radiator flushed and the thermostat replaced when the heat first stopped working. It worked after that for a little while but it stopped working again. My heater coil is fine no leaks on the inside of my car but I noticed when the heat stopped working my car would run really rough especially sitting at a light. When starting my car in the morning or after sitting for some time the engine reves really high around 2 1/2 RPM and continues to go higher untill finally slowing down. Does all this have to do with my water pump and the water not being able to properly circulate through the car? Please help me I've been having problems with this car since my warranty ran out!
May 11, 2009 at 7:30 AM
  • 110,246 POSTS
The water pump can make a griding noise. Is it leaking coolant? As far as the engine RPM's, has the check engine light ever come on?
Regarding your question, I doubt the two problems are related.
Jul 11, 2009 at 4:56 PM
