I cant find the spark plugs so i can change them. Can you walk me through the steps on getting to them on this car?
Feb 23, 2008 at 3:28 AM
JIMMEROK
MEMBER
Your spark plugs are located under the plastic cover running down the top center of your engine. You will have to remove your air intake hoses and some fuel linkages to remove the cover. Once removed you have two coil packs covering two plugs and two spark plug wire on the others.
