2000 Kia Sportage RPM
2000 KIA SPORTAGE
11,487 MILES • 4 CYL • 2WD • AUTOMATIC
DAMOY3
I had problem with my RPM. It wont stay under 3,000 RPM when i go on 70 mph. Its always around 3,500 or 4,00 RPM. The guy at auto-part did the diagnosis and say that its bc of oxygen sensor. I have replaced high and lower sensor and it still having the same problem. I want to solve that problem right away.
Sep 27, 2010 at 5:50 AM
KHLOW2008
  • 41,814 POSTS
Hi damoy3,
Thank you for the donation.
Problem seems to be the torque converter is not locking up.
What were the trouble codes retrieved? I need to know the exact trouble code.
Sep 27, 2010 at 8:12 AM
DAMOY3
The troubleshoot code is P0137 (oxygen sensor). I have replaced the upper and lower oxygen sensor in my Sportage, but the svc engine light is still on and the code is the same (it has been reset before).
How can I deal with the torque converter?
Sep 28, 2010 at 3:03 AM
KHLOW2008
  • 41,814 POSTS
Here are the diagnostics for P0137 DTC P0137: REAR HEATED OXYGEN SENSOR (HO2S) LOW VOLTAGE Diagnostic Aids If more than 155 seconds have passed since front HO2S heating period started, code will set if rear HO2S voltage is less than -150 millivolts. Monitor runs continuously. Two trip fault. Check for: "¢ Short to ground in Blue wire between rear HO2S and ECM. "¢ Rear HO2S malfunction. Procedure NOTE: Record all freeze frame data before disconnecting any connectors or clearing codes. 1. Turn ignition off. Disconnect rear HO2S 4-pin connector and ECM 88-pin connector. Check for continuity between ground and ECM connector terminal No. 39 (Blue wire). See Fig. 5 . If continuity exists, repair short to ground in Blue wire between rear HO2S and ECM. If continuity does not exist, go to next step. 2. Connect rear HO2S connector and ECM connector. Start engine and let idle. When engine reaches normal operating temperature, backprobe and monitor voltage between rear HO2S connector terminal No. 4 (Blue wire) and ground. Increase engine speed to 2000-2500 RPM for 5-10 seconds, then release throttle. Repeat several times while monitoring rear HO2S voltage. Rear HO2S voltage should rise during sustained high RPM and drop significantly when throttle is snapped shut. If rear HO2S voltage does not change as specified, replace rear HO2S. If rear HO2S voltage changes as specified, check rear HO2S connector and ECM connector for loose, damaged or corroded terminals. If problem exists, repair appropriate connector.
https://images.2carpros.com/forum/automotive_pictures/192750_PCMConnector00SportageFig05_1.jpg
SHIFT & TCC SOLENOIDS 1. Ensure ignition is off. Disconnect TCM harness connector. Measure resistance between ground and solenoid terminal # 22 at TCM harness connector. Resistance should be 11-15 ohms at 68 °F (20 °C). 2. If resistance is not as specified, disconnect transmission solenoid connector and check harness between TCM and transmission connector for short or open. If harness is okay, go to next step.
https://images.2carpros.com/forum/automotive_pictures/192750_TCMConnector00SportageFig09_1.jpg
3. Disconnect 3-pin transmission solenoid connector from vehicle harness. Note that solenoids ground through transmission case. Check resistance between 3-pin connector terminals and ground. Replace solenoids as necessary. 4. If resistance is okay, ensure transmission case is grounded and intermittently connect battery voltage to terminals of 3-pin connector. An audible click should be heard from specified solenoid when voltage is applied. If click is not heard, replace solenoid.
Sep 28, 2010 at 4:59 AM
