2000 Kia Sportage rotors
75,000 MILES • 4 CYL • 2WD • AUTOMATIC
LIBBIE
how do you take off rotors on this model kia?
May 4, 2009 at 5:33 AM
DAVE H
  • 13,383 POSTS
FRONT BRAKE ROTOR
Removal & Installation
Raise and support vehicle. Remove front wheels. Remove brake caliper. See FRONT DISC BRAKE PADS & CALIPER. Using a micrometer, measure brake rotor thickness. Using a dial indicator, measure brake rotor runout. Compare to specifications and resurface or replace as necessary. See DISC BRAKE SPECIFICATIONS. To install, reverse removal procedure.
May 4, 2009 at 11:47 AM
