1999 Kia Sportage Speedometer
1999 KIA SPORTAGE
16,000 MILES • 4 CYL • 4WD • MANUAL
ANGELO C. MABUGNON
The Speedometer does not work and millagetoo. what should i do?
Aug 19, 2010 at 7:48 PM
EDWARD.S
  • 166 POSTS
Hi,first have the computer checked for codes.also have the mechanic look at data for the speed sensor. if that working ok, then you need to send the cluster out for repair.
Hope This Helps You,
Good Luck
Edward S.
Aug 19, 2010 at 10:29 PM
