1999 Kia Sportage Mass Air Flow Sensor
HELPMYKIA
  • 1999 KIA SPORTAGE
  • 4 CYL
  • 147,000 MILES
My 99 Kia Sportage, mileage 147,000, started running funny today. When I started it it hesitated and when I went to accelerate it barely moved and shut down. I had to re-start it and try over and over. Finally I figured out once I get it over 1 rpm and keep it there it will keep running but if it gets lower it will die. Is the mass air flow sensor causing this problem?
Tuesday, September 29th, 2009 AT 7:00 PM
  • 110,052 POSTS
The MAF can cause this to happen, but before you start replacing parts for no reason, have you checked fuel pump pressure? Has the check engine light come on?
Wednesday, October 14th, 2009 AT 12:23 PM
