1999 Kia Sportage Mass air flow sensor
85,000 MILES • 4 CYL • 4WD • AUTOMATIC
TITAN891
I went to the Kia dealership about a couple of months ago because the oxygen sensor was bad and I needed it replaced. While I was there they had to fix a million other things because they were recalled. So I drove the car for about a month after I had it fixed then the check engine light came back on again. I took it to auto zone and they read the codes and said that the mass air flow sensor was bad. So I bought the sensor and took it to my dad to have it replaced. He is a mechanic so he also read the codes with his machine and it had the same code. So we replaced it and he cleared it. A couple of days later the engine light came back on. The car started losing power. If I was parked then I put it in gear I would take off and mash on the accerator but the car would just creap along slowly. It wouldn't gain no power for about 10 seconds. When I am at a red light it acts like it wants to idle real crazy. If you got a answer please respond. It was also doing this before we had replaced the sensor.
Jul 5, 2008 at 2:47 PM
KHLOW2008
  • 41,812 POSTS
Hi Titan891,
Scan the code again and see if it is anything different from previous.
Jul 6, 2008 at 2:24 AM
